Jan 26, 2024 9:37 AM UTC
RTC Problem
I use the NUCLEOH563-ZI board and I want to use RTC. I configured the RTC with the LSI clock. I loaded a default date/time. On the other hand, my time does not change...
My Init code :
My source code to retrieve the time
Thank you for your help !
Ghislain
Sarra.SBest answer
Jan 26, 2024 10:04 AM UTC
Hello @Ghislain_Clement,
Please check if the RTC_TR and RTC_DR registers get updated
Also, you may want to check: STM32CubeH5ProjectsNUCLEO-H563ZIExamplesRTC
Sarra.SBest answer
Jan 26, 2024 11:06 AM UTC
THANKS ! I found the solution. I initialized the time before the date and it works.
Jan 26, 2024 11:12 AM UTC
Great! I guess it turned out to be this gotcha!
Jan 26, 2024 11:16 AM UTC
I missed this information ;)
Thanks again !
Ghislain
