Apr 4, 2025 9:11 AM UTC
RAK3172 Module boot mode issues
I hope you are doing well.
I am currently facing critical issues with my RAK3172 module and STM32Cube Programmer setup and urgently need your technical support. Here are the details:
1. RAK3172 Module Issue (LoRa P2P Communication)
  • Initially, the module booted up correctly, but now it does not enter boot mode.
  • I receive a "baud rate not detected" error when attempting to communicate.
  • The RAK Firmware Upgrade Tool fails with a device timeout error, and STM32CubeProgrammer does not work either.
  • Despite this, I can still read the firmware version from the port, so I’m unsure if the IC is damaged.
2. ST-Link & STM32Cube Programmer Issue
  • The device only connects in Hot Plug mode when I press the reset button.
  • In normal mode, it fails to connect and shows RDP Level 0.
  • Releasing the reset button causes an immediate disconnection.
  • I am unable to erase the chip, even in Hot Plug mode or while holding the reset button.
Request for Support
Could you please help me resolve these issues? Specifically:
  1. Are there any hardware requirements (e.g., resistors, connections) I might be missing?
  2. Is there a way to recover the IC or troubleshoot further?
  3. Could this indicate a hardware fault, or is it a firmware/configuration issue?
I urgently need to get this working and would greatly appreciate your prompt assistance. Please let me know the next steps or any debugging methods I should try.
Thank you in advance for your support.
Best regards,
Hetal
Andrew Neil
Apr 5, 2025 10:21 AM UTC
This is primarily a user-to-user forum.
If you want direct support from ST, raise a ticket here: https://ols.st.com/s/
It's a 3rd-party module by RAKWireless - have you tried contacting them for support?
https://www.rakwireless.com/en-us/contact-us
https://forum.rakwireless.com/
