embvis
Jan 14, 2019 9:56 PM UTC
pointer above 0x4000
Why I cannot use pointer above 0x4000. I have declared array form 0x200023d0 [+6000 32bit], so end about 0x28950a10. I am using STM32F769.
Iam getting
Failed to execute MI command:
-data-evaluate-expression *(pDataVectSourceAddress)
Error message from debugger back end:
Cannot access memory at address 0x4000
Mikołaj
Uwe Bonnes
Chief
Jan 14, 2019 10:29 PM UTC
You put your pointer into ITCM ram. It only has 0x4000 size . Put your data somewhere else.
embvis
embvisAuthor
Jan 14, 2019 10:51 PM UTC
Hi, Can you share an example? Do you mean pointer addr or data, because I checked and data are on DTCM region.
Uwe Bonnes
Chief
Jan 15, 2019 10:21 AM UTC
Understand and check your linker script and the memory map of your executable and of the STM32F76x. The programm clearly tries to access pDataVectSourceAddress in the ITCM memory, as the error message implies.
