PCB checklist for a battery-powered STM32 board
Hi All,
Product: STM32 microcontrollers on a board powered from a 1S LiPo battery (3.0 to 4.2 V).
Topic: I would like to learn from your experience about what to check before sending such a board to fabrication.
Goal: A short, practical checklist that helps avoid common problems like random resets, noisy supply rails, and unexpected battery drain.
Questions:
Which power-related items do you always check (decoupling, regulator layout, BOR level, ground plane, test points)?
Which mistakes did you make on your first battery-powered STM32 board that others should avoid?
Any tips, links to app notes (for example ST’s hardware development guides), or personal lessons learned are very welcome. Thanks.
