Jan 6, 2026 6:51 AM UTC
OTA Updates for STM32C091
Hi Team,
This is Vamsi. I am using a smart display with the STM32C091 MCU and would like to implement OTA updates for this chipset. Could you please suggest the best possible way to achieve this?
NaiduBest answer
Jan 23, 2026 6:03 AM UTC
Hi Andrew,
Thank you for sharing the detailed information regarding my query. I'll start the implementation right away and keep you updated on the status.
If I have any concerns or questions, I'll post them here.
MM..1
Jan 6, 2026 8:01 AM UTC
OTA without OTA connect is realy impossible. Read AN2606...
NaiduAuthor
Jan 6, 2026 9:01 AM UTC
I have not understood OTA Connect. Could you please elaborate on this?
MM..1
Jan 6, 2026 3:55 PM UTC
Try you elaborate , what you mean is OTA ?
NaiduAuthor
Jan 19, 2026 5:45 AM UTC
OTA refers to updating the firmware over the air. For ESP32 chipsets, we typically use HTTP requests to download the file and perform the update wirelessly. However, I'm not familiar with the exact procedure for STM32. Please let me know if you need any additional information from my end.
MM..1
Jan 19, 2026 3:02 PM UTC
No info required from your end,  as i write on first message 091 dont have over air connect then OTA is impossible.
