KDIAS.2340
Feb 9, 2020 2:58 PM UTC
Not able to start. I d'loaded MDK529.exe , it is an icon on my desktop. I click on it hoping to run it but it gets me to another screen asking me to install. Is there a clear and comprehensive single set of instructions that actually work?
Most of the links lead to nowhere i.e. 404 error
KDIAS.2340
Mar 28, 2020 10:09 PM UTC
I tried the book by Kerighan & Ritchie' it gave the foll ex.:
lower = 0;      /*  lower limit of temperature table * /
    upper = 300;    /*  upper limit * /
    step = 20;      /*  step size * /
Based on this the Blinky code should follow i.e. lower = thrBUT, upper = NULL, step = NULL but this does not make sense!
Any thoughts?
KDIAS.2340
Apr 30, 2020 11:34 PM UTC
Trying to use Keil for compiling my C program. As a start, I tried compiling the Blinky.c program done by Keil - no luck, although I didn't change anything, got 114 errors, tried another ex, same. So, something I am missing (as always!)
Piranha
Principal III
May 2, 2020 4:33 PM UTC
> What do the 3 parameters signify
Are you incapable of even using Google?
https://www.keil.com/pack/doc/CMSIS/RTOS2/html/group__CMSIS__RTOS__ThreadMgmt.html#ga48d68b8666d99d28fa646ee1d2182b8f
But before even touching RTOS, you should learn the basics.
> I was trying to understand the C code for Blinky but with limited success, may be need a refresher on C. Any suggestions welcome
One can refresh only knowledge he already knows. In your case you must learn the C and MCUs. Probably the best tutorial to start with is this one:
https://www.embeddedrelated.com/showarticle/453.php
