Abhishek Kumar
Nov 21, 2017 1:04 PM UTC
Non-volatile data storage in STM32F7 mcu?
Posted on November 21, 2017 at 14:04
I am using STM32F777II mcu where I wanted to know how to store non-volatile data? I see that this controller's datasheet doesn't say it has any EEPROM.
#eeprom #stm32-f7 #non-volatile #flash
Nov 21, 2017 2:11 PM UTC
Posted on November 21, 2017 at 15:11
There should be 4KB of BKPSRAM (NVRAM) powered by the battery attached to VBAT, this should be part of the PWR/RTC block.
http://www.st.com/content/ccc/resource/technical/document/datasheet/group3/8a/34/ed/7e/4c/04/4b/7a/DM00225424/files/DM00225424.pdf/jcr:content/translations/en.DM00225424.pdf
0x40024000 - 0x40024FFF BKPSRAM
Use a pointer to access, or create a structure for your data and use a pointer to the structure.
Abhishek Kumar
Nov 21, 2017 4:17 PM UTC
Posted on November 21, 2017 at 16:17
Isn't there any storage which does not needs external battery backup?
waclawek.jan
Nov 21, 2017 4:25 PM UTC
Posted on November 21, 2017 at 16:25
Yes, it is - the FLASH; but there are inconveniences related to using it as a backup memory (code execution from FLASH stalls, erase granularity is high, endurance limited).
Joerg Wagner
Senior III
Nov 21, 2017 10:59 PM UTC
Posted on November 21, 2017 at 23:59
I use FRAM, it's fast and very reliable.
For projects Flash will not be used very often, I shift my app to another address (i.e. 0x80020000)
to use the 32kB section(s). I believe in 100K erase operations under normal temperature conditions
and 10-20 years data retention, but nothing is forever...
