Jan 9, 2026 6:01 AM UTC
Newbie looking for help to make a Windows game controller device
Hi, its my first post
Let me introduce myself, my name is Manuel, I am from Spain (English is not my native language) and I have joined the forum looking for help.
My profile is that of a maker with very little programming experience (an AI maker). AI helped me a lot to make the programs
I’m migrating a project from Arduino to an STM32 Blackpill; I managed to get it working on Arduino.
Sim racing pedals
The pedals are a potentiometer (for the accelerator) and a loaded cell (for the brake).
Well, what I thought would be the hardest thing to do—getting the STM32 Blackpill to “read” those sensors—I’ve managed to do. I press buttons on the console and see the changes… but what was easy on Arduino—turning it into a game display for Windows—I’m not being able to do on the STM32… the libraries that Gemini recommends are either missing or don’t work…
I’m looking for help getting Windows to recognize my STM32 as a gaming device. I thought this part would be easier; the Blackpill model is supposed to communicate well with Windows via USB… but so far I haven’t been able to.
Can anyone recommend a resource to help me get Windows to recognize the STM32 Blackpill as a game device? Libraries, tutorials, anything.
Thanks in advance.
Jan 9, 2026 7:18 AM UTC
Hi @Peirof & welcome to ST community !
ST resources are dedicated to supporting genuine ST products (not black pill ...) . We are not committed to ensuring that clones/fakes work properly with the firmware we provide.
Ozone
Principal
Jan 9, 2026 7:44 AM UTC
I would be careful with beating (new) posters with the "fake chip" club over the head before you have any proof.
I have a few Blackpill boards as well, and everything works fine, including debugging with a ST-Link V3MINIE.
Ozone
Principal
Jan 9, 2026 9:58 AM UTC
I think first you need to determine what kind of USB device your game(s) expect as input.
See a list of options e.g. here : https://en.wikipedia.org/wiki/USB#Device_classes
Probably either 00, 03 or 05 ("unspecified", HID or PID).
Then I would look for an appropriate example to use as starting point.
From my (superficial) point of view, the best option would be a device covered by a standard driver, e.g. from Microsoft.You probably would not want to write your own host driver, and get it through the MS signing procedure ...
I am not really experienced with USB stuff, though.
Andrew Neil
Jan 9, 2026 10:45 AM UTC
Welcome to the forum.
As you're already familiar with Arduino, note that there is an Arduino core for STM32:
https://www.stm32duino.com/
https://docs.arduino.cc/libraries/stm32duino-examples/
https://github.com/stm32duino
As already noted, the Black Pill is not an ST product, and adds a number of unknowns in your path.
Therefore, as a newbie, I would strongly suggest that you (at least) start with a genuine ST board; eg, the following have STM32F4s with USB:
NUCLEO-F412ZG, NUCLEO-F413ZH, NUCLEO-F439Z, NUCLEO-F446ZE
via: https://www.st.com/en/evaluation-tools/stm32-nucleo-boards/products.html
These are fully supported by ST, have ready-to-go examples, and come complete with a built-in ST-Link.
Also, USB is quite advanced - not really a beginner's project.
It would be best to spend some time on the basics:
https://community.st.com/t5/stm32-mcus-products/for-better-learning-stm32-programming-and-debugging/m-p/719485/highlight/true#M260696
Some STM32 learning references:
https://community.st.com/t5/stm32-mcus-products/for-better-learning-stm32-programming-and-debugging/m-p/719468/highlight/true#M260690
Good luck!
Jan 9, 2026 1:02 PM UTC
What are you trying to achieve exactly? Something local, that only your machine recognises it as a gaming device, or that any machine does it. Also which MCU are you using.
You need us to provide with more infos, also if you will build a client for your machine or not.
Andrew Neil
Jan 9, 2026 2:07 PM UTC
Black Pills are generally based on STM32F401 or F411, although it does seem that F103 "Black Pills" also exist:
https://stm32-base.org/boards/STM32F103C8T6-Black-Pill.html
@Peirof This is another risk with the "Pill" boards - there are many variations, and no guaranteed consistency of supply.
So, if you do use one, please post photos of the one you actually have, and give a link to where you bought it.
How to write your question to maximize your chances to find a solution
Jan 9, 2026 2:15 PM UTC
Werent there issues with blue pill boards a couple of years ago where the specifications of the product sheet didnt match the actual MCU?
Anyways, @Peirof you might come to the point where you question your sanity, and in those cases a proper device directly from ST can save you from paranoia that the hardware is faulty (I have been there). They arent that expensive also.
Jul 25, 2026 7:40 PM UTC
Sim racing pedals
Thanks in advance.
I have the same issue while trying to get an STM32 board recognised by Windows as a proper gaming input device. Reading sensors and getting the microcontroller to process the values seems to be one part of the challenge, but making Windows understand the device as a joystick/game controller through USB is a completely different step. I have also found that many suggested libraries and examples are either outdated, missing, or do not work with the exact STM32 board being used, which makes troubleshooting quite difficult.
I’m also looking for a clear guide on how to configure the STM32 Blackpill for USB HID game controller functionality. It would be helpful to know whether the problem is related to firmware setup, USB descriptors, bootloader configuration, or choosing the right STM32 libraries. If anyone has successfully converted a Blackpill into a joystick, pedal controller, or similar sim racing device, I would really appreciate any tutorials, example code, or resources that helped you get Windows to detect it correctly. I’m facing the same challenge and would like to understand the proper approach instead of just trying random libraries.
