GR.5
Dec 6, 2022 9:29 AM UTC
Keil uv5 application hangs when I add Large C file and The only way out is "killing" uVision via Windows 10 task manager.
MCU: STM32L071cz
Application : MDK-ARM essentials version 5.35
 when I try to build large project. The "Build Output" window freezes at a random point in the build. uVision is still responsive but I can't stop the build or quit uVision. The only way out is "killing" uVision via Windows 10 task manager. Does anyone know the root cause for this?
AMuya.1
Jan 19, 2023 4:25 PM UTC
Have you been able to resolve this? I am having the same issue
