Charlie CHEN
May 13, 2019 5:20 AM UTC
Keil Debug
Hi professor,
I`m trying to use debug mode with keil.I get it in to the function and it run the function without press run button,but when I stop it ,it go in to hardfault.
Is any one have faced the problem before?
May 13, 2019 5:57 AM UTC
SystemInit faults? Perhaps step in to that and review the code. Inspect Hard Fault location reported by processor, it has registers for that.
Are you using RAM which needs a clock enabled?
Charlie CHEN
May 16, 2019 8:12 AM UTC
Hi @Community member​ ,
Thanks for your reply!
I have enabled the appropriate clock ,and I cannot check the register cause it can`t run normally,just stuck in Reset_Handler.
Is there any problem occur?
Thanks again!
May 17, 2019 2:43 PM UTC
Use Stop to see where it is.
Turn off the "Run to main()" setting of the debugger, and start stepping into/through the SystemInit() function. Determine where things go wrong, and where exactly it ends up.
