Interface onboard WiFi module of STM32BL475
I’m trying to interface the onboard ISM43362 Wi-Fi module of the STM32BL475 using STM32CubeIDE, but I couldn't find any proper resources or example code online.
STTwo-32
Hello @Shreyu1001
The only available examples to make WiFi work on this board are those WiFi examples.
Best Regards.
STTwo-32
but in that theres a common folder which has files... so how do i use it in my project... like pins connections and configurations..
Andrew Neil
I don't understand the problem: all projects are just folders and files - where, exactly, are you stuck?
either do it graphically in CubeMX (standalone, or within CubeIDE), or just write the code.
Hi i was wondering if you finally found some documentation or a solution for that
I tried a lot of stuff over the last couple of days but nothing worked
Thank you
