bmwael1
Oct 21, 2013 2:33 PM UTC
Impot Matrix
Posted on October 21, 2013 at 16:33
I want to import a Matrix which his size is 140*200 to my program.
This matrix is create by MATLAB (file format .mat) i can copy it to txt file.
How can i call in main program to be useful after ?
have I to separate the row and column by space or ;
I'm using STM32F4
Thanks you ^_^
#matrix #matlab #stm2f4 #size
Oct 21, 2013 3:01 PM UTC
Posted on October 21, 2013 at 17:01
I'd suggest you write a small C app, or script (AWK, Pearl, etc), and process that table into a ''C'' format that you can #include into your compilation.
int MyTable[10][10] = { { 1, 2, 3, .. }, .. , { .. } };
Alternatively if you have some file storage (SD Card, FatFs, NAND), you could store the text output from MatLab as a file, and simply parse that data into a structure/table at run time.
bmwael1
bmwael1Author
Oct 21, 2013 3:29 PM UTC
Posted on October 21, 2013 at 17:29
My table have a big size, i can't write it manually, i found a function called fopen but i didn't  know how to use it
some components of table are:
523 528 536 496 452 439 433 439  ............................. 200 column
250 658 025 ............................................
140 Row
Oct 21, 2013 4:12 PM UTC
Posted on October 21, 2013 at 18:12
Yeah, I'd class the app/script method as ''mechanical''. The STDIO and fopen/fread/fclose, and file handling concepts are pretty fundamental CS stuff.  Try this, or Google for some others.
http://www.cs.bu.edu/teaching/c/file-io/intro/
