PKuma.12
Aug 16, 2019 11:23 AM UTC
I want to select a controller to design a energy meter. Is it necessary that controller should have EEPROM memory in built?
I am really confused that is it necessary or not. Because if I am going to the series STM32F030 these controller doesn't have in built EEPROM memory.
Tesla DeLoreanBest answer
Aug 16, 2019 1:28 PM UTC
Perhaps you work with someone who has a better grasp of the project requirements and specific use cases?
If you have a value that is constantly changing, and must be remembered, I don't think FLASH is appropriate, at the very least it is not the best choice.
Aug 16, 2019 11:28 AM UTC
Perhaps look at using the L0 series parts instead.​
PKuma.12
PKuma.12Author
Aug 16, 2019 12:32 PM UTC
My question is that could I used a controller without EEPROM for my application?
PKuma.12
PKuma.12Author
Aug 16, 2019 1:48 PM UTC
Yes as because it is energy meter so its value will be continuously change.
so you mean that EEPROM must be present to store values?
Aug 16, 2019 2:39 PM UTC
No, I'm saying that FLASH is perhaps the least suitable. Data could be journalled, and spread across multiple pages, to mitigate wear and failure.
Perhaps think about NVRAM (RTC/BKPRAM)
What design choices are driving the use of the F0 over the L0 parts?
PKuma.12
PKuma.12Author
Aug 20, 2019 9:51 AM UTC
As because of the cost reduction.
Thank you for the answer.
