AWalu.3
Dec 3, 2021 12:02 PM UTC
I had interface EEPROM with STM32G4 board and I have to flash a project code in EEPROM as my Flash memory of the board is not sufficient for my project(code size is large).So is it possible to flash my code inEEPROM and execution of code store in EEP
Dec 3, 2021 12:14 PM UTC
Is it within the processors address space? I'll assume not, so no.
I​f you need more program space use QSPI NOR Flash
AWalu.3
AWalu.3Author
Dec 6, 2021 4:22 AM UTC
It is not within processor address space.
AWalu.3
AWalu.3Author
Dec 6, 2021 4:24 AM UTC
So is it possible with On board EEPROM or not? (flashing and execution of project code)
Muhammed Güler
Senior III
Dec 3, 2021 1:36 PM UTC
https://www.st.com/resource/en/application_note/dm00227538-quadspi-interface-on-stm32-microcontrollers-and-microprocessors-stmicroelectronics.pdf
The above document explains how to use QSPI storage. You can store code or data up to 4GB on QSPI devices.
AWalu.3
AWalu.3Author
Dec 6, 2021 4:21 AM UTC
Ya I went through above document but I am using STM32G431MBTx board and QSPI connectivity is available for that board. In document also QSPI connectivity is for limited u/c board only. So what so what will be solution for that?
AWalu.3
AWalu.3Author
Dec 6, 2021 4:53 AM UTC
sorry *QSPI connectivity is not available to STM32G432MBTx board
AWalu.3
AWalu.3Author
Dec 6, 2021 4:55 AM UTC
Ya I went through above document but I am using STM32G431MBTx board and QSPI connectivity is not available for that board. In document it is also mention that QSPI connectivity is available for limited u/c board only. So what so what will be solution for that?
S.Ma
Principal
Dec 8, 2021 5:15 AM UTC
What is the codesize, flash size, unused ram and how much short are you in flash ?
