TGhau.2088
Oct 16, 2019 8:34 AM UTC
I am using Keil IDE and during debugging in the call stack + locals window the variables I have defined are appearing as not in scope.
I am getting warnings that AccY, AccZ and Avg are not being used.
Pavel A.
Oct 16, 2019 11:18 PM UTC
Usually the compiler is correct.
Try to disable optimization. Optimization removes unused code and variables.
As you see, lines 144, 145 are optimized out.
-- pa
Oct 16, 2019 11:29 PM UTC
Probably in a register in MCU and FPU. Look at the actual assembler generated and where it is holding the values.
Get rid of all the delays, and print values to a console. Shouldn't need to step this stuff.
