BTrem.1
Senior
Jan 14, 2021 4:04 PM UTC
How to use CMSIS-DSP with STM32G431 in Keil compiler? Getting compiler error
I want to use a CMSIS-DSP FIR function in my code and get a compile error:
compiling phase_det.c...
../Drivers/CMSIS/Include/core_cm4.h(81): error: #35: #error directive: "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
 #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
..\Src\phase_det.c: 0 warnings, 1 error
In Keil I used the 'Manage Runtime Environment ' to add CMSIS-DSP Library. In my source code file I haven't yet added the FIR, but I did add the include "arm_math.h".
What does the above error mean? The STM32G431 does have an FPU as far as I know (Ref Manual). Anyway, I want to use fixed point FIR.
What steps do I need to take to properly install the CMSIS-DSP Library?
Andrew Neil
Andrew NeilBest answer
Mar 25, 2021 5:48 PM UTC
Did you post this on the Keil forum 2 months ago?
https://community.arm.com/developer/tools-software/tools/f/keil-forum/48498/how-to-use-cmsis-dsp-library-on-stm32g431--getting-compile-error
EDIT
Ah - the OP here is 2 months old, too: @Igor Cesko​  has just woken it up!
Igor Cesko
Mar 25, 2021 3:46 PM UTC
Andrew Neil
Mar 25, 2021 5:46 PM UTC
Andrew Neil
EDIT
BTrem.1
BTrem.1Author
Senior
Mar 29, 2021 3:47 AM UTC
Yes that's me. Problem resolved with order of #includes.
Andrew Neil
Mar 29, 2021 9:52 AM UTC
Then please update your Keil thread, and mark the solution there.
Also choose 'Best Answer' here:
