May 23, 2025 6:24 AM UTC
How to see data on Wireshark for stm32f407
HI
Can you help me how I can see data on wireshark. I have connect LAN cable to 8742 and which is connected to stm32 via RMII wire and board is connected to CPU via USB .
First I am unable to see my etherent device name on wireshark.
second How I can see data on wireshark. kindly help me.
B.R
Ashish
LCE
LCEBest answer
Principal III
May 23, 2025 6:29 AM UTC
You need to know:
- the PC's ethernet interface's name, then select that
- your STM32's IP address, simply watch the stream, or filter for that IP address
LCE
LCEBest answer
Principal III
You need to know:
Ash1Author
May 26, 2025 7:16 AM UTC
HI
I can see now. Thank you so much
B.R
Ashish
Andrew Neil
May 23, 2025 8:26 AM UTC
Wireshark just sees Ethernet (or whatever) - it neither knows nor cares anything about STM32.
So there is nothing specific to STM32.
So just follow the standard Wireshark documentation:
Wireshark User Guide: https://www.wireshark.org/docs/wsug_html/
https://www.wireshark.org/learn
https://ask.wireshark.org/questions/
This does, of course, require that you have a basic understanding of networking ...
Try a general internet search for "Wireshark beginners"...
@Ash1 wrote:
I have connect LAN cable to 8742 ...
You mean a Microchip LAN8742 Ethernet Transceiver: https://www.microchip.com/en-us/product/lan8742a ?
@Ash1 wrote:
... and which is connected to stm32 via RMII wire and board is connected to CPU via USB .
What do you mean by "CPU" here ?
A diagram would help.
Maybe also some good, clear photographs of your setup
