LThal
Jan 24, 2019 4:31 PM UTC
How to add multiple post-build steps?
I'd like to know if there's a way to either add multiple lines for post-build processing. I've worked in other IDE's where you get multiple lines for entering post-build commands, and I've run into a situation where it would come in handy. Thanks.
Jan 24, 2019 4:51 PM UTC
What IDE, I don't see you specify any one specifically and this looks to be in the general forum.
Keil provides for several steps, I think you can run batch files, and you can definitely run your own multi-function applications.
GNU/GCC you could presumably add things to the makefile file or use scripts.
LThal
LThalAuthor
Jan 24, 2019 5:02 PM UTC
Oops, my mistake. I'm using True Studio. When I ran into the same situation on Atmel Studio it had the option to enter multiple lines for post-build commands.
