Dhiraj Ghodmare
Jun 5, 2021 7:53 AM UTC
how can I fetch external eeprom 24c64 using stm32f0 cortex MO based controller ?
I use stm31f0 micro controller & 24c64 eeprom for store data but unfortunately I'm not able to fetch and store data you have any solution please help me I'm attached my code bellow
char data_eeprom[255];
void write_eeprom(uint16_t posi,uint8_t dt)
HAL_I2C_Mem_Write(&hi2c1,0xA0<<1,posi,0xff,&dt,1,1000);
HAL_Delay(5);
uint8_t read_eeprom(uint16_t posi)
uint8_t dt;
HAL_I2C_Mem_Read(&hi2c1,0xA0<<1,posi,0xff,&dt,1,100);
return dt;
void writeString_eeprom(uint16_t posi,char*dt)
write_eeprom(posi,strlen(dt));
for(int a=0;a<strlen(dt);a++)
write_eeprom(posi+1+a,dt[a]);
void readString_eeprom(uint16_t posi)
uint16_t l_str=read_eeprom(posi);
memset(data_eeprom,0,255);
for(int a=0;a<l_str;a++)
data_eeprom[a]=read_eeprom(posi+1+a);
waclawek.jan
Jun 5, 2021 12:21 PM UTC
Observe SDA/SCL using oscilloscope/logic analyzer.
Jun 5, 2021 12:39 PM UTC
0xA0 is already left aligned you shouldn't need to shift it again.​
Dhiraj Ghodmare
Jun 6, 2021 6:22 PM UTC
I remove shift right by one, its work but "data_eeprom buffer" shows value "0x19" in character
Jun 6, 2021 6:30 PM UTC
What's the 0xFF here?
#define I2C_MEMADD_SIZE_8BIT   (0x00000001U)
#define I2C_MEMADD_SIZE_16BIT   (0x00000002U)
Getting any errors/status reported?
