mhdizgah
how can add cpp library to keil 5.11 ?
Posted on September 17, 2014 at 17:06
hi when i add a cpp library to keil project,it shows this error:
its while i have no problem with c libraries
tnks
#stm32f103 #cpp-library #keil
Andrew Neil
Posted on September 17, 2014 at 22:21
Well, it clearly tells you to, ''check 'Options for Target - Utilities''' - so did you do that?
And the error is coming from FCARM - so have you checked the documentation  for FCARM?
