UJuer.1
Jul 28, 2020 6:42 PM UTC
Hi, just started with TrueStudio. Trying to code a class with a template pattern results in error: template class { ... }; Error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token Any help welcome...
Jul 28, 2020 9:35 PM UTC
Is your code in C or C++? Ensure the compiler sees it as C++.
UJuer.1
UJuer.1Author
Jul 29, 2020 7:49 AM UTC
A class without a template pattern makes no problem, so it must be C++. Only a template <whatever> has a problem.
Jul 29, 2020 1:43 PM UTC
I'm aware you're trying to write C++ code. But if the file is named "something.c", the compiler will treat it as a C file.
If I use template within a C file, I get the exact error you've described:
...\printf.c:38:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token
 template <class T>
mingw32-make.exe[3]: ***
