CMilo.1
Jun 6, 2020 2:39 PM UTC
Hello! I've got problem with compiler. I use Keil and CubeMx. When I press 'Build' or 'Rebuild' and there are no errors, program compiles about 4 minutes, is there any way to make this faster? Thanks.
Tesla DeLoreanBest answer
Jun 6, 2020 3:03 PM UTC
Select the Version 6 Compiler, it is much faster
CMilo.1
CMilo.1Author
Jun 7, 2020 5:18 PM UTC
Now I have a problem. When I select version 6 compiler, it doesn't create .axf file, but version 5 creates normally. Do you know what is problem here? Sorry for questioning..
Jun 7, 2020 5:53 PM UTC
If you don't get a .AXF file you'll need to look at what part of the compile failed.
Version 6 doesn't like one of the -c99 command line options as I recall.
Remove the command line option, and use the check-box item instead.
CMilo.1
CMilo.1Author
Jun 6, 2020 5:06 PM UTC
Thank you! It worked :)
