SYLVIA
Sep 26, 2019 6:47 AM UTC
Hardfault handler using I2C based Accelerometer
When I plug on my device and run my code on the attolic debugger for 1st time my code is working as per my given logic.However if i stop my debugger and then re-run,my program is getting stuck at hardfault.
SYLVIA
SYLVIAAuthor
Sep 26, 2019 7:23 AM UTC
Please help anyone
Ozone
Principal
Sep 26, 2019 9:12 AM UTC
You provided very little information.
You can:
Use a debugger to find the code line you code hardfaults.
Instrument your code, to do the same without running in the debugger.
Check the values of the SCB registers, to see why it hardfaulted : www.keil.com/appnotes/files/apnt209.pdf
SYLVIA
SYLVIAAuthor
Sep 26, 2019 9:50 AM UTC
Basically I am using HAL library.So just after HAL_Init() it is going to hard fault..Since I a very new to embedded coding can you tell What exact information you want?
Ozone
Principal
Sep 26, 2019 10:09 AM UTC
I don't use HAL.
You should be able to step into the HAL_Init() function, down to the line where it faults.
If necessary, you can even switch to disassembly mode in the debugger and single-step to the faulting instruction.
