parth kothiya
Oct 5, 2019 1:03 PM UTC
Hard fault occur stm32 imprecise data access violation true studio.
my application code running some time inside mcu then suddenly hard fault occur so i debug my application found hard fault occur inside mcu how to solve this. 0690X000009k4wWQAQ.bmp0690X000009k4wRQAQ.bmp
Oct 5, 2019 1:33 PM UTC
Inspect the faulting code. There is likely a write instruction a few instructions earlier that is failing, thus the "imprecise" tag.
Pavel A.
Oct 5, 2019 11:06 PM UTC
parth kothiya
Oct 7, 2019 1:50 PM UTC
problem solved i change interrupt priority high and low not same priority of both interrupt
Jan 25, 2024 10:58 PM UTC
I know I'm several years late, but could you elaborate on this solution? I am running an RTOS and I am getting the same error. I have enabled various ISR's (UART, ETH, GPIO, DAC etc) and they currently all have the same priority. What would you change based on this knowledge?
Jan 25, 2024 11:09 PM UTC
Could be something entirely different.
Just diagnose WHY your situation is faulting rather than blindly shot-gunning.
Look at what's faulting, more likely to be bad pointer or misaligned write, or an insufficiently large stack.
Dump some useful / actionable data about what the system is objecting too.
https://github.com/cturvey/RandomNinjaChef/blob/main/KeilHardFault.c
NVIC has priorities and preemption levels and you can split how the bits are allocated.
NMish.1
Dec 4, 2021 11:15 AM UTC
how can i change the priority in stm32cube ide?
KnarfB
Dec 4, 2021 6:16 PM UTC
In the .ioc (device configuration) view > System Core > NVIC. There are also tbas for the individual periperals.
hth
KnarfB
