PKuma.12
Feb 3, 2020 11:03 AM UTC
Getting error flash loader error while debugging in STM32L151RBT6 using IAR. It is showing User error:Reset failed-target not halted.
Hi I am using STM32L151RBT6 controller card. This was working properly also there was no issue in debugging. I am using IAR Embedded Workbench 6.4.
I Added this line to my code: FnEraseEpromWord(0x080800F5,1); as because I want to erase data for this address. After executing this line debugger was stopped.
After that I am not able to debug my code this shows following errors:
  1. User Error: Reset failed-Target not Halted.
  2. failed to load flash loader.
Please help to find out the solution.
Thank you.
