er3481
Oct 21, 2022 9:27 AM UTC
eeprom write page error
I am trying to write some datato external eeprom with I2C_EEPROM_WritePage function, but it doesn't write everytime. Sometimes it can write and sometimes it can't. I am using standart peripheral I2C library and using the write page function below. Any advise ?
void I2C_EEPROM_WritePage(unsigned char* pBuffer, unsigned short MemAddr, unsigned short NumData, unsigned char mode)
 unsigned char byteRemain;
 if(I2C_EE_State & I2C_STATE_ERROR)
 I2C_EEPROM_ErrorCallback();
 if((NumData == 0) || ((MemAddr+ NumData) > (I2C_DRIVER_MAX_SUPPORTED_SIZE - 1)))
 return; /* nothing to write or not allowed */
 while(NumData > 0)
 /* calculate remaining bytes till page end */
 byteRemain = I2C_currentSettings->EE_pageSize - ((unsigned short)MemAddr % I2C_currentSettings->EE_pageSize);
 /* bytes fit in page */
 if(byteRemain >= NumData)
 if(I2C_EEPROM_Write(pBuffer, MemAddr, NumData, mode) == I2C_ERROR)
 // write error
 WDG_RESET();
 NumData = 0;
 /* bytes overlap with next page */
 else
 /* write bytes into page till page end */
 if(I2C_EEPROM_Write(pBuffer, MemAddr, byteRemain, mode) == I2C_ERROR)
 // write error
 NumData -= byteRemain;
 MemAddr += byteRemain;
 if(mode == I2C_MODE_NORMAL)
 pBuffer += byteRemain;
 return;
I2C_eResult I2C_EEPROM_Write(unsigned char *pBuffer, unsigned short MemAddr, unsigned short NumData, unsigned char mode)
 /* check I2C Driver state */
 if((I2C_EE_State & I2C_STATE_READY) && !(I2C_EE_State & I2C_STATE_ERROR))
 if(NumData == 0)
 return I2C_DENIED; /* nothing to read */
 else
 /* update state machine */
 I2C_EE_State |= I2C_STATE_BUSY;
 I2C_EE_State &= ~I2C_STATE_READY;
 /* generate start condition TX */
 if(I2C_EEPROM_Start(I2C_Direction_Transmitter) == I2C_ERROR)
 return I2C_ERROR; /* communication error */
 I2C_EEPROM_SendAddr(MemAddr); /* send 16 bit address */
 while(NumData > 0)
 I2C_SendMasterByte(*pBuffer);
 NumData--;
 pBuffer++;
 /* wait until byte transmitted */
 I2C_EE_Timeout = I2C_currentSettings->I2C_timeoutWr + 1; // +1 with I2C_timeoutWr = 1 allows
 // that for sending timer interrupt can occure at least once
 while(!I2C_CheckEvent(I2C_DEV_EEPROM, I2C_EVENT_MASTER_BYTE_TRANSMITTED) && I2C_EE_Timeout > 0)
 /* Send STOP Condition */
 I2C_GenerateSTOP(I2C_DEV_EEPROM, ENABLE);
 /* Wait to make sure that STOP control bit has been cleared */
 I2C_EE_Timeout = I2C_currentSettings->I2C_timeoutDefault;
 while((I2C_ReadRegister(I2C_DEV_EEPROM, I2C_Register_CR1)) & I2C_CR1_STOP)
 if(I2C_EE_Timeout == 0)
 I2C_EE_State |= I2C_STATE_ERROR | I2C_ERR_TX;
 return I2C_ERROR;
 // reset write control
 I2C_EEPROM_WriteControl(DISABLE);
 I2C_EE_State |= I2C_STATE_READY;
 I2C_EE_State &= ~I2C_STATE_BUSY;
 return I2C_SUCCESS;
 else
 /* driver not ready */
 I2C_EE_State |= I2C_STATE_ERROR;
 return I2C_ERROR;
