A Maq
Nov 22, 2018 8:46 AM UTC
Difference between IWDG watchdog reload RLR Register and WINR window register
I am working with STM32F779 MCU and using IAR Embedded Workbench IDE for programming the chip.
I have a situation where I am using a IWDG independent watchdog timer in window option enabled mode. That is loading window value in IWDG_WINR register.
Can anyone tell the difference between Reload value (IWDG_RLR) and WINR value. Should I use same value for both registers?
Also, my understanding is that once RLR loaded for rest of the time loading WINR will result in automatically re loading ​RLR without writing Aaaa in KR register is that right?
