May 28, 2025 11:40 AM UTC
Connect NUCLEO-F746ZG LoRaWAN Gateway to TTN
In TTN, it says my gateway is connected to other cluster.
I'm not able to change it to connected.  What should I do?
Andrew Neil
May 28, 2025 12:00 PM UTC
Are you sure you have the correct ID for your actual gateway?
If you've just used a default, someone else has already registered that ...
KaaviyaAuthor
May 29, 2025 3:37 AM UTC
I have not used a default gateway ID . I have used the actual ID only. What should I do?
Andrew Neil
May 29, 2025 8:05 AM UTC
Where did you get that ID ?
