Mar 1, 2024 8:02 AM UTC
Cannot able to install ST-Link Driver for STM32C031c6
Hi I have purchased STM32 NUCLEO -C031C6 board and trying to install the driver ST- Link driver for my system.
I was unable to install the driver  kindly do a check.
  • The board (STM32 - NUCLEOC031C6)
  • IDE - keiluvision Version - 5
Mar 1, 2024 10:13 AM UTC
Hello @VELVIZHI ,
Try a different USB comm cable (not designed for battery charger).
I recommend you download and install STM32CubeProgrammer tool.
VELVIZHIAuthor
Mar 5, 2024 5:01 AM UTC
I have Separate USB Cable for Programming which is not designed for battery charger and I have already installed the STM32Cube IDE but still facing the same issue Unable to connect the ST Link Debugger. Could you please connect in teams and resolve the issue.
Billy OWEN
Mar 5, 2024 3:24 PM UTC
Hi @VELVIZHI
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Regards,
Billy
