旭熊.1
September 28, 2021
atollic truestudio调试时Live Expression显示功能�?�?�用,表达�?�??示Multiple errors reported. 1) Failed to execute MI command:-var-create - ,请问怎么解决?
Hello 旭熊.1,
Please elaborate your issue in English to increase the chances of getting you a reply from our community members, as most of the people on this community can speak English but not Chinois.
I advise you to share more details about the issue and a screenshot of the errors, this will help us to review easily your issue.
Check your project settings, as it can be a problem into Truestudio setting. Check the variables and defines.
Which version of atollic are you using ? which device are you using ?
Please keep us informed about your progress on this issue.
Imen
