LHerm.1
Feb 16, 2021 3:34 PM UTC
Arduino serial Monitor / STM32 Nucleo equivalent ?
Hello everyone, I would like to know wath's the STM32 equivalent of the serial monitor on Arduino .. Wath's the simpliest way to display integer value like temp or number with a nucleoF401re stuff ?
Thank a lot for your responses !
Javier1
Javier1Best answer
Principal
Feb 16, 2021 4:13 PM UTC
With arduino you dont have access to all the cool debugger capabilities of stm32.
You can stop the code and create halt points, thats very handy.
  1. If you hate the debugger you can use a USB-UART converter
  2. if you need the mcu not to be interrupted you could use stmstudio (the debugger will try to fish in real time your variables directly from memory)
  3. if a console is what you need you could use printf() to the stm32cubeide console
hit me up in https://www.linkedin.com/in/javiermuñoz/
Peter BENSCH
Feb 16, 2021 4:04 PM UTC
The easiest way is the virtual COM port. It tunnels the connected UART from the target (here STM32F401) via USB and makes its data available to every terminal running on the host. These data could e.g. be sent from the target UART with printf.
/Peter
Javier1
Javier1Best answer
Principal
LHerm.1
LHerm.1Author
Feb 16, 2021 4:16 PM UTC
Thank for your responses. It helps me a lot !!
