Sep 1, 2025 4:54 AM UTC
Wiring issue with BIG KEY button module on Arduino?
Has anyone used those BIG KEY button modules before? I’m trying to hook one up to an Arduino, but I’m not sure if I’m wiring it right since the signal seems stuck low. Do they normally need a pull-up resistor or should it just work out of the box?
Best answer
Sep 6, 2025 2:52 AM UTC
Thanks for the replies! I ended up sorting it out — turns out the button module I had was already tied to the BOOT signal, so I just had to adjust the wiring a bit. Working fine now.
mƎALLEm
Sep 1, 2025 2:41 PM UTC
What board are you using? and what is that BIG KEY button? better to put pictures or link to it.
Best answer
Andrew Neil
Sep 1, 2025 3:50 PM UTC
Does this have anything to do with ST ?
It doesn't seem so - hence @mƎALLEm's questions!
It sounds like you'd be better asking on the Arduino forums: https://forum.arduino.cc/c/other-hardware/196
Or, if you're using STM32Duino, on their forum: https://www.stm32duino.com/
They will want to know what Arduino you're using!
How to write your question to maximize your chances to find a solution
