kirill70674
August 27, 2020
Which antenna connection is right?
I am currently working on custom BLE sensor for my university project and whole design is based on your ​STEVAL-BCN002V1B evaluation board. When it came to antenna routing I discovered that your schematic diagram and antenna's (ANT016008LCS2442MA1) pattern layout do not match.
On figure 3 in data brief for Bluetooth module antenna's (U5) feed point has no direct connection with GND net but the opposite pin(radiator electrode) does.
In antenna's datasheet in "Example of Antenna pattern layout" section radiator electrode has no direct connection with GND but feeding line does.
Can you comment this mismatch?
Thank you.​
