satnam
Jul 21, 2008 12:45 AM UTC
where is CP15 (buffered/un buffered)
Posted on July 21, 2008 at 02:45
satnam
satnamAuthor
May 17, 2011 7:54 AM UTC
Posted on May 17, 2011 at 09:54
Dear All,
I am usign a 16 bit memory device with EMI.
The device works only when i use the buffered mode in my MCU. But if i de-comment the #define Buffered in my 91x_conf.h in Keil, all the other functions of MCu stop working. i am not even able to toggle a pin in buffered mode.
Can some one help me by telling how to use buffered mode....
And if some one can tell what/where is Control register - CP15 in STR9.
Thanks.
satnam
satnamAuthor
i am not using any bootloader.
currently i am using ulink to program my MCU.
regards,
16-32micros
Hi satnam.singh,
Did you use some kind of IAP bootloader first and then jump to your program ? could you please provide your keil start-up file if i can o the same in my board, so I can investigate and let you know.
Regards,
STOne-32.
