Feb 4, 2026 12:31 PM UTC
What is the standard lead time of the demo board STEVAL-CCA044V1
See the subject, what t is the standard lead time of the demo board STEVAL-CCA044V1?
Peter BENSCH
Peter BENSCHBest answer
Feb 4, 2026 2:25 PM UTC
@simonpeng I can only give you the same answer as before:
The community can serve as a global public reference for technical issues, with product users primarily assisting each other. However, questions regarding availability are commercial and always temporary, so you should clarify them with your local distributor.
/Peter
Andrew Neil
Feb 4, 2026 1:05 PM UTC
That would depend on where you're buying from: ST eStore? Distributor? Other?
Best to contact your supplier direct:
https://www.st.com/content/st_com/en/contact-us.html
Peter BENSCH
/Peter
