pchignon
Oct 3, 2005 6:39 AM UTC
What is the maximum frequency generated with timers ?
Posted on October 03, 2005 at 08:39
pchignon
pchignonAuthor
Oct 3, 2005 5:21 AM UTC
Posted on October 03, 2005 at 07:21
I'll be pleased, if it is possible to use the timer to provide a 12Mhz clock. Is it possible? What is the maximum frequency? How to?
Is there another mean to get a 12MHz clock?
Thanks,
Ludo
ben2
I dont think you could get 12Mhz from a timer. I could be wrong.
Probably your best bet (Assuming a 48Mhz MCLK) is to use the CKOUT pin. But this means running the APB2 peripherals at 12Mhz also.
