a_shemet
Jun 28, 2005 9:04 AM UTC
What is the latest version of the ST10 Flasher?
Posted on June 28, 2005 at 11:04
a_shemet
a_shemetAuthor
Jun 21, 2005 1:29 PM UTC
Posted on June 21, 2005 at 15:29
At now I'm using ver 2.3C, is there is a plan to make update?
If so, it is quite desirable to have possibility to use it in the command-line mode, because usually in the development process the filename is the same for particular project. It is not so convenient to select it every time before downloading.
Also, it is desirable to release COM-port after download, because this port often used to communicate with ST10.
At now for this it is necessary to close Flasher.
Is it posible to add some button like ''Open/Close COM-port''?
Maybe the forum is not good place for such messages, but I don't know where is the right one.
Best regards, Andrey
michaelgaus9
Jun 27, 2005 6:59 AM UTC
Posted on June 27, 2005 at 08:59
where can I download this new version?
cu,
looking
najoua
Jun 27, 2005 7:07 AM UTC
Posted on June 27, 2005 at 09:07
This version is not yet available on internet. It will be available some months later.
Regards,
