YW.1
What is the body marking of M24C32-RMN6TP
Please help to provide the body marking surface of this material. There is no description in the spec, so it is impossible to confirm whether the material used is correct. Thank you!
MANUFACTURER: ST
MANUFACTURER PN: M24C32-RMN6TP
Pierre P.
Pierre P.Best answer
It should be 24C32RP.
BR
Pierre
Pierre P.
BR
Pierre
YW.1
YW.1Author
Thank you!  You're right.  The label on the first line is exactly what you said it was.  But can you be a little more specific, because the second line also has labels
Pierre P.
2nd line XYWZ depends on several parameters and i'm unable to guess because:
X is 1 digit of manufacturing plant
Y is 1 digit of manufacturing year
W is 2 digit of manufacturing week
Z is 1 digit equal to "T"
YW.1
YW.1Author
Ok, I see. Thank you very much for your answer
Best Regards
