raunaque
Oct 11, 2004 12:29 AM UTC
what is hexfsm file
Posted on October 11, 2004 at 02:29
what is hexfsm file
raunaque
raunaqueAuthor
Oct 9, 2004 1:42 AM UTC
Posted on October 09, 2004 at 03:42
hi
what is hexfsm file and what for it is used .
i found it to be called in for data coprocessor
can any body help me
thanks
alok2
You rightly said, the fsm is used by the compiler for DTC available in the 7265x. The fsmfiles are the source code for the DTC plug-ins and the .hex are generated output in op-codes. You can open the xx_fsm.hex file in text format to see the opcodes.
These files are actually included as an array in the source code, which are then loaded in the DTC RAM for execution, when required.
