SMusc.1
What is 211 ST- EZ204 IC ?
Hello every ones; i found this component from ST: 211 ST- EZ204.
Is a four pin Integrated circuit. does anyone know what it is? I cant found it data scheet
Peter BENSCH
Peter BENSCHBest answer
You can see from this that a photo is always very important: it is an SO-8 package that has eight pins instead of four. The device in question is an LM211D.
Good luck!
/Peter
Peter BENSCH
It is always helpful to have sufficient information for a meaningful answer. In this case, a clearly legible photo of the part in question is missing. Can you please upload it?
SMusc.1
SMusc.1Author
here the photo
Peter BENSCH
Good luck!
/Peter
SMusc.1
SMusc.1Author
tks a lot, you solved my big issue))))))))thank again
