zarozaro
Jun 5, 2006 11:57 AM UTC
WFI doesn't reduce power
Posted on June 05, 2006 at 13:57
zarozaro
zarozaroAuthor
May 12, 2006 2:22 PM UTC
Posted on May 12, 2006 at 16:22
I'm trying (unsuccessfuly) to use WFI mode to reduce power consumption between interrupts. Program execution stops when I clear WFI bit in RCCU_SMR register, but current remains the same. Once interrupt is detected program execution resumes.
I tried it with 2 eval boards - IAR (STR712FR2) and Hitex (STR710FZ2).
zarozaro
zarozaroAuthor
May 15, 2006 10:03 AM UTC
Posted on May 15, 2006 at 12:03
I'm powering the board from external power supply and measuring the total current drawn from the board, so it includes LEDs, RS232 and CAN drivers.
I tried several MCLK/FCLK/PCLK combinations, here are some of the results:
MCLK FCLK PCLK mA
32 32 32 80
32 16 16 71
16 16 16 58
16 8 8 54
8 8 8 47
Application I'm running is very similar with AN2100 application note ''STR71x power management''.
I cannot get any current reduction with WFI mode (RCCU->SMR &=0xFE;), eventhough processor stops program execution until detects interrupt.
Thanks.
zarozaro
zarozaroAuthor
Does anybody have better luck reducing current consumption in WFI mode?
Thanks.
