Arman Ilmak
Senior
Aug 30, 2019 12:16 PM UTC
Weird bug in stm8 IAR compilers ?
Hi.
I have faced a weird problem using IAR compilers.
Errorstatus=0;
 Relay_Off;
 delay_ms(200);
 if(Errorstatus==1){
 Errorflag=1;
In this part of my code after I switch the relay off, I put a delay and if an interrupt occurs Errorstatus mentioned in the code changes from 0 to 1 in interrupt handler and the if must change the Errorflag from 0 to 1, but it wont work though Errorstatus is changed from 0 to 1!!
What is the problem?
    After Forever
    Senior III
    Aug 30, 2019 1:06 PM UTC
    Make sure both Errorflag and Errorstatus are declared as volatile if you change/access them in the interrupt handler.
    Arman Ilmak
    Senior
    Aug 30, 2019 1:18 PM UTC
    I have defined them as int variables.
    After Forever
    Senior III
    Aug 30, 2019 1:20 PM UTC
    Change to volatile int and try again.
