lmeyerovich
Jan 20, 2010 12:10 AM UTC
WDG Reset event flag
Posted on January 20, 2010 at 01:10
roppen
May 17, 2011 7:58 AM UTC
Posted on May 17, 2011 at 09:58
That's because the SYSSTATUS register bits are cleared by writing a 1. You're or'ing in the current value of the SYSSTATUS register to itself, effectivly clearing each bit that's been set.
If you want to clear the SCU_FLAG_LOCK bit it you should be doing this-
SCU->SYSSTATUS = SCU_FLAG_LOCK;
rudi2
do you perhaps have a solution for this. I am having the same problem that after a software watchdog reset, the SCU->SYSSTATUS did not set the WDG_RST flag accordingly.
Thank you!
lmeyerovich
I am working on STR91x processor
I am trying to use WDG_RST(WDG Reset event flag) in SCU_SYSSTATUS register.
While initializing PLL, after setting SCU_FLAG_LOCK
SCU->SYSSTATUS |=SCU_FLAG_LOCK
all other bits in SYSSTATUS register have been reset, so I am loosing WDG_RST information.
I have also tried to do the same thing manually in debugger and observed the same beviour.
Can anybody help?
Thank you
