jliu
May 25, 2004 11:54 PM UTC
watch dog
Posted on May 26, 2004 at 01:54
watch dog
jliu
jliuAuthor
May 17, 2011 10:00 AM UTC
Posted on May 17, 2011 at 12:00
I thought all need to do to enable the watchdog timer is WDKEY = 0. if I don't reset WDRST periodically then will result in a reset of system. But an experiment has showed this way doesn't work. Can anybody tell me why?
s_abbot
ben, the WD is enabled at bootup, all you need to do is keep feeding WDRST, to disable the WD then you need to concern yourself with WDKEY.
Stephen
[ This message was edited by: sabbot on 14-05-2004 10:06 ]
jliu
jliuAuthor
I've figured out the watchdog problem using the trick posted early in this forum. It never works if follow the way stated by ST datasheet.
joseph2399
Ben007,
The watchdog timer in the uPSD32xx works well. Have you been able to resolve your issue? If not, please contact us at:
mailto:apps.psd@st.com
Please include the following information:
Name
Company Name
Phone Number
Location (City, State, Country)
uPSD part number of device being used (3234, 3254, etc.)
Application
Projected annual volume (units)
Regards,
uPSD Applications Engineering
[ This message was edited by: uPSD on 18-05-2004 07:20 ]
lwang
Could you tell us what that ''trick'' is? Is the watchdog reset by accessing PCON?
