VNLD5160
Hi at all.
Can VNLD5160 work with a normal STM32 CPU with 3.3V logical levels?
I don't find this information in datasheet...
Thanks...
Peter BENSCH
Well, the data sheet mentions two important points:
  • Vsupply = VIN = 4.5-5.5V
  • VINTH = 1...3.5V (table 8)
This means that you either use a level translator or configure the GPIO of the STM32 as an open drain with external pull-up. As the VNLD5160 can only switch at a few kHz, the simpler and cheaper open drain variant may be sufficient.
Does it answer your question?
/Peter
