August 30, 2023
Vl53l5CX coverglass
i am currently testing the vl53l5cx lidar sensor without a coverglass, but i will need soon to use a coverglass(dusty environment). When using the coverglass, can the vl53l5cx (with Xtalk calibration) still detect object at close range(from 2cm to 60cm)? And when using the coverglass, do the vl53l5cx still need a calibration with Xtalk for far away object(>60cm)?
Thank you
