Explorer
August 30, 2023
VL53L4CX vs Vl53L5CX?
Currently have the VL53V0X, Need a sensor that maintains high accuracy within the short distance as well as the long distance, speed is also a priority. I understand the Vl53L5CX has the multi zone distance sense, does it also work well as a single object distance tracker?  If speed and accuracy are desired, should I purchase the VL53L4CX or the Vl53L5CX?
Is there anything I should be made aware of prior to purchase?
