March 2, 2024
VL53L1X-SATEL pinout is not clear on the datasheet, help required.
Hi
I want to connect the VL53L1X-SATEL to ESP32 (3.3v) via I2c interface, but I cannot find the pins on the datasheet. The datasheet shows a J1 block of 10 pins but not sure where the locations of SCL, SDA, GND, VCC. One more question, does VL53L1X-SATEL run on 3.3 voltes and work with  Melopero_VL53L1X.h> library?
I appreciate your help.
Arthur
