jhill1
Aug 31, 2004 5:01 AM UTC
Viewing RAM
Posted on August 31, 2004 at 07:01
Viewing RAM
jhill1
jhill1Author
Aug 24, 2004 4:18 AM UTC
Posted on August 24, 2004 at 06:18
I am using the ST7FLITE09 and I have run out of code space in which to put my diagnostic software. All I need to do is see the internal ram. Any thoughts?
shreya
I am not sure I understand you problem completely. Do you mean you are performing ''stand-alone debugging''?
1/ Fyi-The inDART h/w+s/w allows real-time debugging at low cost
2/ One suggestion-You could execute a small piece of code in RAM that saves the required part of RAM into EEPROM and then read the EEPROM to retrieve the values.
