simon6
Oct 3, 2005 10:28 AM UTC
Vega will not access boot flash
Posted on October 03, 2005 at 12:28
simon6
simon6Author
Aug 31, 2005 2:26 PM UTC
Posted on August 31, 2005 at 16:26
We have a new ST Vega design and are trying to make it boot. We have all the necessary clocks running correctly, and the SYSRSTO working as specified.
We are failing with getting both signals necessary read the boot flash.
If we select ISA bus mode, then ISAOE# is asserted, but not RMRTCCS#. If we select Local bus mode then FCS[1:0]# are both asserted, but not PRD#.
Any suggestions would be gratefully received.
granitvt
Sep 1, 2005 1:51 AM UTC
Posted on September 01, 2005 at 03:51
Is the MASTER# signal in ISA bus mode have the corresponding level?
kaouther
This could be an invalid strap options on your design.
I advise you to check your hardware settings.
